Home > General > Instrument cluster repair guide |
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 |
Hi guys,
Wed May 08 2019 10:11pm |
Yes, that's the rumour dry joints, but I wouldn't know where to look. If everybody is having similar issues it must be on the same components. The question is which ones. 2008 Range Rover Sport 2.7 SE Zermatt Silver. |
Thu May 09 2019 11:56am |
I found a Russian site with more info about the instrument cluster. Unfortunately it is in Russian.
Thu May 09 2019 2:55pm |
Try this
Thu May 09 2019 5:47pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I have a feeling unless you are seriously into your electronic repairs I would leave it to the professionals as you could easily make it ten times worse. There are companies out there that specialise in repairing these units for around the £150 mark,,, remove the unit, post it to them and they will turn it round in a day or 2,,,, unless you are local to them as some offer a workshop service whereby they remove the unit as well.
Thu May 09 2019 6:19pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
it is good advice that.
Thu May 09 2019 6:29pm |
I solved the problem with a cheaper alternative.
Tue Jun 04 2019 12:27pm |
Glad you've got it sorted,,, definitely was a good idea getting a professional to carry out the work. 2010 RRS, TDV8
Tue Jun 04 2019 3:18pm |
thanks for the feedback |
Tue Jun 04 2019 4:39pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Great news! A handy tip for others Kev
Tue Jun 04 2019 8:16pm |
shorler Member Since: 02 Sep 2019 Location: Swindon Posts: 5 |
Is this the issue that causes the Hazards to flash, doors to lock and fault codes 'vehicle lean when cornering','HDC Fault', 'Parking break fault,'ABS Fault'.
Sun Sep 15 2019 7:10pm |
I had all those symptoms except 'vehicle lean when cornering' and 'ABS fault'. I don't have a sunroof tho but technician said could have been a leak. Looked for leaks but found nothing. Cluster was my only option at the end. And it was the cluster. 2008 Range Rover Sport 2.7 SE Zermatt Silver. |
Sun Sep 15 2019 9:12pm |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
As an electronics engineer I would certainly reflow the connectors, as vibration often causes problems there, but I'd be surprised if the two IC's needed reflowing.
Mon Sep 16 2019 8:36pm |
