![]() | Home > General > Good independent garages in kent? |
Spangler Member Since: 02 Mar 2019 Location: Kent Posts: 98 ![]() ![]() ![]() |
Didn't have it long enough to get an oil & filter change so can't help I'm afraid.
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
I will be there on the morning of the 24th, for a while you wait oil & filter change, they use Morris Multivis C1 ADT 5W30 fully synthetic, I have read up on this and it seems to be perfect for the engine.
Update as promised...
Appreciate you taking the time out to update on your visit to AHL. When I spoke to Harold he did mention that Angus was the "expert" which is supported from the conversation you had with him. Took a drive there last week as mine was potentially going to be towed there and I was concerned that the rural location may cause an issue for the recovery driver - if you avoid coming in via Lenham its not that tight. Looked a decent enough set up from what I could see from the gates.
