Home > Wheels & Tyres > Rear tyres
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
Rear tyres
I’ve just checked the rear tires on the Range Rover Sport and on the very very outside edge (nearly on the sidewall) they are down to the thread..
I’ve got 4 tyres ordered at a Tyrepro place near me so they will fit etc. They will also do a free alignment check on the Hunter machine with an additional cost if it requires adjusting.
The guy who manages the place is very knowledgeable and has done my X5 but I’m concerned about the RR as apparently it needs to be in some mode for alignment. This could be a problem as the suspension doesn’t work and it’s just always in normal mode.
What do you think?
Post #577166 Sat Mar 16 2019 4:41pm
geoffsnook
It should be in tight tolerance mode which you should be able to do with an IDD tool but i had my Discovery 3 done when not in it and that was fine are you sure your rear wishbones are not worn as if they are get them changed first as it would be a waste to have to do it twice Thumbs Up
Post #577167 Sat Mar 16 2019 4:49pm
Themoog
I’ve no idea about the rear wishbones although one of them looks like it’s been replaced not long before we got the car. The car drives straight with no knocks or bangs.
Post #577169 Sat Mar 16 2019 5:04pm
geoffsnook
have the bushes checked first then to see if there's any play Thumbs Up
Post #577172 Sat Mar 16 2019 5:15pm
Themoog
Pah! I had the tyres replaced yesterday and there was a lot of wire protruding from the inside edge of the rears..
Couldn't get the alignment checked as they were very busy so I'll go back in a few days.
Post #577524 Thu Mar 21 2019 6:40am
