![]() | Home > Wheels & Tyres > Rear tyres |
It should be in tight tolerance mode which you should be able to do with an IDD tool but i had my Discovery 3 done when not in it and that was fine are you sure your rear wishbones are not worn as if they are get them changed first as it would be a waste to have to do it twice |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I’ve no idea about the rear wishbones although one of them looks like it’s been replaced not long before we got the car. The car drives straight with no knocks or bangs. |
have the bushes checked first then to see if there's any play |
Pah! I had the tyres replaced yesterday and there was a lot of wire protruding from the inside edge of the rears..
