![]() | Home > Off Topic > Have you got drive on car ramps |
5 ton max probably means both ramps each ramp is 2.5 ton x2 equals 5 ton,,your sport will weigh about 2.7 ton but you won’t have that much weight on the ramps as you’ll only have the front or rear on them at any one time.Probably 3/4 of ton on one ramp if that. Andy.
Andy I hope you’re right but my gut instinct is 1.25 tonnes per ramp. Hopefully I’m proved wrong.
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi Steve,
Even at 1.25 ton per ramp you should be ok,as you drive the front end on most of the weight will be distributed to the rear & vice versa when reversing on them.People say to me how can you lift a Rangerover weighing nearly 3= ton with a 2 ton jack,,,I’m not lifting all the vehicle at once,only 1 corner at a time. Andy. 21 Ford Ranger Gone but not forgotten Focus RS Red Edition 2015 RRS AB Fuji. 2014 RRS SC Santorini 2016 VW Amarok 2014 RRS AB Fuji 2012 RRS Red Edition Fuji 2015 Nissan Navara 2012 RRS SE Santorini 2008 RRS White 2007 RRS Santorino |
something like this which has a 50/50 front/rear split
What Tyrefitter said. I used my Halfords 2 Ton trolley jack to lift the nose wheel of a Tornado Jet out of the ground at the highlands aviation museum a few years back. No issue. And that was about 20 to 30 Ton all up. 2019 5.0 SC SVA (Current)
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
I have the 5.8 tonne plastic ones, they are awesome. so easy to lug around, don't slip, well worth the money.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
Or, you could mark round when a tyre touches the ground, calculate that area and multiply it by the tyre pressure to get the load... ...I'll get my coat. |
Well the seller responded yesterday and said the load limit for the 2 ramps is 2.5 tonnes. I’ve told my wife to keep the email for when it collapses on me she can buy a new L405 with the claim |
