Home > Off Topic > Have you got drive on car ramps
Stevepd
After the gearbox oil change recently I saw Bodsy use the plastic ramps. Bingo I want some this would make life so much easier. After narrowing it down I’ve purchased a pair, but having received the Katsu 161914 pair (2 ramps) there is a label on the box saying 2.5 ton max. Slightly annoyed as the advert said upto 5 tonnes. Seller is confirming before I open the boxing.
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #575556 Tue Feb 19 2019 7:04pm
Tyrefitter
5 ton max probably means both ramps each ramp is 2.5 ton x2 equals 5 ton,,your sport will weigh about 2.7 ton but you won’t have that much weight on the ramps as you’ll only have the front or rear on them at any one time.Probably 3/4 of ton on one ramp if that. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #575559 Tue Feb 19 2019 8:12pm
Stevepd
Andy I hope you’re right but my gut instinct is 1.25 tonnes per ramp. Hopefully I’m proved wrong.
Post #575577 Tue Feb 19 2019 10:09pm
riverblanche
Hi Steve,
this may be a bit out of the box thinking but have a search (youtube?) for racing cars and corner weight set up,
istr the set up is by using four scales to set weights on each corner/tyre may help you understand
or may just confuse Laughing
.ps. Andy's right
. Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #575578 Tue Feb 19 2019 10:17pm
Tyrefitter
Steve.
Even at 1.25 ton per ramp you should be ok,as you drive the front end on most of the weight will be distributed to the rear & vice versa when reversing on them.People say to me how can you lift a Rangerover weighing nearly 3= ton with a 2 ton jack,,,I’m not lifting all the vehicle at once,only 1 corner at a time. Andy.
21 Ford Ranger
2015 RRS AB Fuji.
2016 VW Amarok
2014 RRS AB Fuji
2015 Nissan Navara
2008 RRS White
2007 RRS Santorino
Post #575581 Tue Feb 19 2019 10:42pm
riverblanche
something like this which has a 50/50 front/rear split
Post #575582 Tue Feb 19 2019 10:53pm
Brit Plumber
What Tyrefitter said. I used my Halfords 2 Ton trolley jack to lift the nose wheel of a Tornado Jet out of the ground at the highlands aviation museum a few years back. No issue. And that was about 20 to 30 Ton all up. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575596 Wed Feb 20 2019 1:51pm
shepp
I have the 5.8 tonne plastic ones, they are awesome. so easy to lug around, don't slip, well worth the money.
If you have doubts about the rating, just drive the car on them, suitable plastic ones don't creak, bend or flex. They are incredibly rigid with weight on. I can understand your concern, as something so light shouldn't hold such weight with ease.
https://www.google.com/url?sa=i&source...0700768760 MY12 RRS HSE
Gone 4.2 supercharged RRS
Gone 90
Gone s2000
Post #575630 Wed Feb 20 2019 11:15pm
HughN
Wales
riverblanche wrote:
Hi Steve,
Or, you could mark round when a tyre touches the ground, calculate that area and multiply it by the tyre pressure to get the load...
...I'll get my coat.
Post #575639 Thu Feb 21 2019 8:10am
Stevepd
Well the seller responded yesterday and said the load limit for the 2 ramps is 2.5 tonnes. I’ve told my wife to keep the email for when it collapses on me she can buy a new L405 with the claim Shocked
Post #575647 Thu Feb 21 2019 1:33pm
