Home > Technical > Lost Power on Motorway
leebrotherton
hi,
I am new to this forum and hoping someone can help me, I purchased a 2007 Range Rover sport 2.7tdv6 three months ago and aren’t having much luck. In the short time I have had it it’s had new heated seats, new heater matrix and a new turbo pipe, the current issue is- while driving on the motorway I lost acceleration but the engine was still idling, it showed every warning there is on the dash ( engine fault, gear fault, hdc fault, parking brake fault + every warning symbol was on ) it rolled to a stop on the hard shoulder, I turned off and tried to restart but it wouldn’t. I had it towed to the mechanic who did the previous work but he specializes in Petrol models so is stuck. He cleared all previous fault codes and turned it over producing 1 new code,
Incorrect fuel pressure. He contacted Land Rover direct who said although not 100% it will be the high pressure fuel pump at a cost of around £1500. I have spoken to another independent LR specialist who says it won’t be the pump, it will be the fuel filter as the car is overdue it’s service and have no idea how well it had been serviced before.
I admit I rushed into the purchase of this vehicle but am determined to make the best of it.
I hope someone can steer me in the right direction as I am getting conflicting information and obviously don’t want to spend £1500 and it still not work.
Thanks for you patience in reading the lengthy post
Post #574917 Sun Feb 10 2019 1:50am
As I belive a bad battery/alternator or possibly brake light switch or bad bulb can cause all the warning lights etc. to come on and flash amongst other things, you also say it won't start, is the engine actualy turning over or just dead, I think I would give the battery a good charge and go from there, start from the cheapest option first and work up.
Post #574918 Sun Feb 10 2019 2:14am
leebrotherton
Thanks for reply, the battery is fully charged, the mechanic is going to check the fuel filter tomorrow to see if that is clogged
Post #574928 Sun Feb 10 2019 8:52am
Camelrock
Might be worth checking the intank fuel pump as well. If it’s an old or blocked filter it could of damaged the pump. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
2018 Discovery 5 HSE lux current
1994 Dakar current
Post #574992 Sun Feb 10 2019 10:35pm
Pufftmw
Were you doing a steady maintained speed?
This has happened to me a couple of times. Fuel filter, low pressure (in tank) pump, high pressure pump in that order of checking. The first 2 are cheap to do.
Post #575004 Mon Feb 11 2019 10:02am
leebrotherton
Update
We have ruled out fuel filter, low pressure pump so fitting high pressure pump on Saturday. Fingers crossed
Got genuine pump and belt kit for £710 + £250 fitting so not as bad as I thought.
Post #575025 Mon Feb 11 2019 4:57pm
Brit Plumber
Have the garage not tested the HP pump? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #575167 Wed Feb 13 2019 2:44pm
leebrotherton
Hi, yes he has tested it now, it’s only pushing at 40 bar I think he said so he’s pretty certain it’s the hp pump
Post #575169 Wed Feb 13 2019 3:27pm
