![]() | Home > Technical > Lost Power on Motorway |
As I belive a bad battery/alternator or possibly brake light switch or bad bulb can cause all the warning lights etc. to come on and flash amongst other things, you also say it won't start, is the engine actualy turning over or just dead, I think I would give the battery a good charge and go from there, start from the cheapest option first and work up.
leebrotherton Member Since: 10 Feb 2019 Location: Leeds Posts: 5 ![]() ![]() |
Thanks for reply, the battery is fully charged, the mechanic is going to check the fuel filter tomorrow to see if that is clogged |
Might be worth checking the intank fuel pump as well. If it’s an old or blocked filter it could of damaged the pump. 2008 G4 RRSport TDV8 current
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Were you doing a steady maintained speed?
Update
Have the garage not tested the HP pump? 2019 5.0 SC SVA (Current)
Hi, yes he has tested it now, it’s only pushing at 40 bar I think he said so he’s pretty certain it’s the hp pump |
