Home > Technical > Lost Power on Motorway |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
As I belive a bad battery/alternator or possibly brake light switch or bad bulb can cause all the warning lights etc. to come on and flash amongst other things, you also say it won't start, is the engine actualy turning over or just dead, I think I would give the battery a good charge and go from there, start from the cheapest option first and work up.
Sun Feb 10 2019 2:14am |
leebrotherton Member Since: 10 Feb 2019 Location: Leeds Posts: 5 |
Thanks for reply, the battery is fully charged, the mechanic is going to check the fuel filter tomorrow to see if that is clogged |
Sun Feb 10 2019 8:52am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Might be worth checking the intank fuel pump as well. If it’s an old or blocked filter it could of damaged the pump. 2008 G4 RRSport TDV8 current
Sun Feb 10 2019 10:35pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Were you doing a steady maintained speed?
Mon Feb 11 2019 10:02am |
Update
Mon Feb 11 2019 4:57pm |
Have the garage not tested the HP pump? 2019 5.0 SC SVA (Current)
Wed Feb 13 2019 2:44pm |
Hi, yes he has tested it now, it’s only pushing at 40 bar I think he said so he’s pretty certain it’s the hp pump |
Wed Feb 13 2019 3:27pm |
