Home > General (L494) > Rear brake pads need replacing after 11,000 miles????
lee551247
Just had a call from the dealer saying my rear brake pads need replacing after 11,000 miles! The fronts have 6mm left on them so they are fine, surely the fronts should wear out before the backs as the majority of the braking is done on the front. The car is a 2018 SVR, surely it wont need rear pads every 11,000 miles!??
What mileage are others getting out of rear pads? 2018 Range Rover Sport SVR arrived but now rejected!
2019 Range Rover Sport SVR in Madagascar orange arrived but never heard it coming but now rejected!
2019 Range Rover Sport SVR in Madagascar orange incoming
Post #574046 Tue Jan 29 2019 12:08pm
drdelrrs
The electronic traction/stability control often uses the rear brakes and can accelerate the pad wear. It might be coming on too soon/aggressively - get it checked.
I had a Jag with this issue at about the same mileage - I'd never replaced rear pads on any of our cars (before or since) inside 60,000 miles!!
Post #574051 Tue Jan 29 2019 1:50pm
PIG88
I also had this happen on a Jag (XK). At the time, the dealer told me it was probably due to pad wear caused by the auto handbrake release feature. Don’t know if that was true but I now generally try to remember to release the electric handbrake manually rather than just driving away. Current: 2020 P400e HSE Dynamic
Gone: 2016 SDV6 HSE
2012 SDV6 SE
Post #574053 Tue Jan 29 2019 2:19pm
wilf
Additional rear pad wear comes from their being used for "anti dive" around town - uses the rears very hard in
preference to the fronts. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
By the age of 50 you have the face you deserve - George Orwell.
Post #574054 Tue Jan 29 2019 2:23pm
PIG88
That makes sense, Wilf. When I had the problem, the car was doing a lot of mileage in slow moving heavy traffic every day. Current: 2020 P400e HSE Dynamic
Gone: 2016 SDV6 HSE
2012 SDV6 SE
Post #574055 Tue Jan 29 2019 2:35pm
lee551247
I've never had a car that has needed rear brake pads before the front.
I see what you are saying about the anti dive but if that is the case i think they need harder pads in the back as rear pads every 11,000 miles seems excessive. 2018 Range Rover Sport SVR arrived but now rejected!
Post #574056 Tue Jan 29 2019 2:50pm
wilf
it is not uncommon in jags. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Post #574057 Tue Jan 29 2019 2:50pm
Black Bess
I suspect the dealer is being very cautious, as is their way. If the pads look like they may wear down before the next service (plus a margin for error) they will recommend replacement. I suppose the flip side is that you would justifiably complain if the warning light came on, or the pads went metal to metal, after they had serviced it.
I am soon going to replace the pads on all 4 wheels on my 2014 HSE (not an SVR). I just bought the pads from my local factor for about £50 per axle, so I will be doing them when it warms up outside. The rear pads are much thinner than the fronts, so tend to last the same length of time. Mine are being replaced for the first time at 33,000 miles.
Post #574068 Tue Jan 29 2019 5:17pm
duckworthparts
Site Sponsor
Ask the measurement of the rear pads? Sophie Alltoft
Send a paypal payment direct using this link www.paypal.me/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: danroberts@duckworthlandrover.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Can also supply OEM & Aftermarket parts
Post #574069 Tue Jan 29 2019 5:18pm
lee551247
The rear pads apparently measured 3mm, do you need a diagnostic machine to wind the callipers back? 2018 Range Rover Sport SVR arrived but now rejected!
Post #574073 Tue Jan 29 2019 6:03pm
Disco_Mikey
No, there is a manual procedure Thumbs Up
Post #574076 Tue Jan 29 2019 6:26pm
lee551247
That sounds good, where do I find the manual procedure👍 2018 Range Rover Sport SVR arrived but now rejected!
Post #574078 Tue Jan 29 2019 6:44pm
Disco_Mikey
On Google someplace Thumbs Up
Post #574079 Tue Jan 29 2019 6:48pm
Coedlan
http://www.rrsport.co.uk/forum/topic47676.html
Post #574083 Tue Jan 29 2019 8:21pm
