![]() | Home > General (L494) > Rear brake pads need replacing after 11,000 miles???? |
The electronic traction/stability control often uses the rear brakes and can accelerate the pad wear. It might be coming on too soon/aggressively - get it checked.
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
I also had this happen on a Jag (XK). At the time, the dealer told me it was probably due to pad wear caused by the auto handbrake release feature. Don’t know if that was true but I now generally try to remember to release the electric handbrake manually rather than just driving away. Current: 2020 P400e HSE Dynamic
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
Additional rear pad wear comes from their being used for "anti dive" around town - uses the rears very hard in
That makes sense, Wilf. When I had the problem, the car was doing a lot of mileage in slow moving heavy traffic every day. Current: 2020 P400e HSE Dynamic
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 ![]() ![]() |
I've never had a car that has needed rear brake pads before the front.
it is not uncommon in jags. MY2016 HSE D SDV6 - gone due to fuel dilution problems.
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
I suspect the dealer is being very cautious, as is their way. If the pads look like they may wear down before the next service (plus a margin for error) they will recommend replacement. I suppose the flip side is that you would justifiably complain if the warning light came on, or the pads went metal to metal, after they had serviced it.
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
Ask the measurement of the rear pads? Sophie Alltoft
The rear pads apparently measured 3mm, do you need a diagnostic machine to wind the callipers back? 2018 Range Rover Sport SVR arrived but now rejected!
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4443 ![]() ![]() ![]() |
No, there is a manual procedure |
That sounds good, where do I find the manual procedure👍 2018 Range Rover Sport SVR arrived but now rejected!
On Google someplace |
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
