Home > Technical > Brake pad warning...
Page 2 of 3 <123>
MAW
ENVOY wrote:
At the last service the dealer said mine needed replacing, im waiting till the light comes on the dash then ill get them changed, mines done 13.5k at the moment mostly driving around lanes with a bit of motorway driving about 80/20 split, as VA said get a firm quote, ive been quoted big differences from other garages
Ditto - I had svc 3 weeks ago ish and they said then they needed doing - but poss had upto 5K left on them so I wanted to get the mileage... ahm.... out of them. Wanted around £335 from memory, I did post it that day on a service related thread...
Post #81218 Wed Feb 07 2007 4:29pm
ENVOY
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Arctic Frost
I suppose they are only telling us that the pads need changing because they are getting close to needing it, if we chose not to then that's up to us, but if like you there is about 5k left and you are getting 20k on a new set, then in theory by not having them done yet you are saving £83.75 Thumbs Up some of my Previous cars
P38 Range Rover Autobiography
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
RRS 3.0 HSE BALTI BLUE
current vehicles
RRS 3.0 L494 Autobiography
Audi R8 V10 Spyder
AC Cobra
Landrover Defender 90
Landrover Defender 110
Suzuki Jimney
Post #81222 Wed Feb 07 2007 4:41pm
MAW
Exactly ! Thumbs Up
Post #81224 Wed Feb 07 2007 4:45pm
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
On our D3 we did about a further 300 after the brake wear light came on. In that time the discs got badly scored and the dealer said they needed replaced. I actually think the brake wear indicator sensor itself might have damaged the disc, so if you hear any metallic sounds from the brakes when rolling forward, suggest you change the pads asap.... RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #81258 Wed Feb 07 2007 9:04pm
Josh
On my service last week they said the pads were getting near needing replacement and that I should wait for the sensors to raise the alarm. TDV6 - gone
TDV8 - gone
Post #81345 Thu Feb 08 2007 10:11am
I suppose a lot depends on how often you want or can be at the service dept too. I had mine done at the 1st service because it would have been inconvenient to go back a few weeks later to have them done.
Post #81346 Thu Feb 08 2007 10:14am
Zipperman19
United States 2006 Range Rover Sport 4.4 V8 HSE Buckingham Blue
Well I tend to brake kind of hard so I needed new pads at 13,000 miles. And they're just starting to squeak again at 20,100 miles.
Post #81582 Thu Feb 08 2007 6:09pm
MAW
Out of interest - when anyone has had them done - all 4 together or fronts or rears, also which go first the fronts or is it pretty even?
My first change so unaware as yet...
Post #81761 Fri Feb 09 2007 9:45am
I had all 4 done, but fronts were much more worn (fairly understandably, they take the brunt of stopping 2.5t of metal) Very Happy
Post #81794 Fri Feb 09 2007 11:01am
Bod
I would try and get the pads replaced before the light comes on. Otherwise youl have to pay for a new sensor Another 20 quid or so, replace rears while your on.
Should get two sets of pads to a set of rotors
Post #82976 Tue Feb 13 2007 8:57pm
ENVOY
Hi Bod surely you get the sensor wires when you buy a set of pads Question and why replace the rears at the same time if they dont wear at the same rate.
And Welcome to the site some of my Previous cars
RRS 2.7 HSE Silver
RRS TDV8 HSE silver
FFRR Vogue black
Disco3 HSE silver
RRS 2.7 HSE silver
current vehicles
Audi R8 V10 Spyder
AC Cobra
Suzuki Jimney
Post #83028 Tue Feb 13 2007 10:36pm
Brian Mason
United Kingdom 2012 Range Rover Sport SDV6 HSE Sumatra Black
I replaced my front and rear pads with Greenstuff when fitting Rossini front discs. Didn't let LR anywhere near the car.., why pay £100+vat when Oily Joe around the corner does it for £30ph cash!!! Thumbs Up
The pads were the original first set from new when removed, front had worn much more than rear. Managed to re-use the sensors, no problem. My LR Parts man told me on the hush-hush NOT to use LR pads on straight replacements and go for Mintex instead which are superior (LR=Ferodo, I think?). Question
This is now getting too technical for a moron like me so I'll quit while I'm ahead! Cool
Post #83055 Tue Feb 13 2007 11:23pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
just had mine changed at 36,000 km (22,500 miles) There was no light on the dash yet but the service said I was down to the last mm. I don't know if I should believe him but I think the mileage is about right anyway RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #83227 Wed Feb 14 2007 2:39pm
MAW
I had mine done on Monday - needed them for a work run south... down to barely more than 1mm on front with warning light flickering. It looks like the sensor contact was just about starting to score the front disks, I have the pads in the boot to examine more closely out of interest but I'd now advise if the light is on get them done without trying to get remaining mileage from them - not worth the risk of scored disks and increased ££...
Post #83342 Thu Feb 15 2007 8:54am
MikeP
Im just wondering guys...
Do discs squeak if they're cold or wet?
On the point can you change them yourselves on the RRS? I remember someone said you cant do 4x4's yourselves because the jacks arent big enough to be able to lift the car? And you dont get a dealer stamp when changing discs anyway do you?
Sorry for the rather silly questions I've always had my mechanic just say this needs doing etc etc. Michael Potter
Rangey Lover/BMW Driver
Post #83516 Thu Feb 15 2007 3:45pm
Page 2 of 3 <123>
