Home > General > RRS 3.6 V8 diesel or 4.4 V8 petrol ??
Mart
Hi I'm new , haven't got the car yet but about to get one , always wanted one of these cars and as we all don't want to buy a money pit...I've narrowed it to one of these engines , I'm not on about economy more about reliability
Good or horror stories both welcome , thanks Thumbs Up
Post #572325 Thu Jan 03 2019 9:28pm
geoffsnook
I have the supercharged petrol engine so i am biased but as far as i am aware they are more reliable but still have a few issues Thumbs Up
Post #572329 Thu Jan 03 2019 9:40pm
4.2SC.
4.4 is rare
Post #572337 Thu Jan 03 2019 10:07pm
Scrumpy
I'm biased too!
I have had the 4.2SC for 2 and a half years and (touch wood) not had a single engine issue (had a few electrical issues though).
From what I know, it depends on the typical daily journeys you do too. Short daily journeys = petrol. Longer daily journeys = Diesel or Petrol (if you can afford petrol!) 2016 RRS SVR Estoril Blue
Post #572346 Fri Jan 04 2019 12:26am
Brit Plumber
I think you’re limiting your self to the oldest RRS when looking at the 4.4, at least if you look st the 4.2 you can buy a car that at its youngest could be 10 years old.
Depending on budget, I’d look at the 2010MY TDV8 or 5.0 SC, if the budget won’t stretch, a 09MY TDV8 or 4.2 SC. A perfect service history is essential and if on the TDV8, the Turbos have been replaced. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #572353 Fri Jan 04 2019 9:04am
Mart
Wouldn't it be cheaper to fix 4.4 one on 4.2 supercharger itself cost 400+ ... Don't mind repairs but don't want to put fortune into it all the time , and if it runs fine I might think of converting it to LPG but that's a long term , in there any 4.2 running LPG here ?? Question
Post #572388 Fri Jan 04 2019 12:56pm
SC are fairly reliable though.
And so much fun
you will spend ages looking for a 4.4! Try it !
Post #572394 Fri Jan 04 2019 2:24pm
gogsy1956
I have the 3.6 V8 and as brit plummer says, turbo's are an expensive item,,, I'm keeping my fingers crossed!. Most other things are par for the course no matter what model you get,,, front arms, wheel bearings, brakes. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #572398 Fri Jan 04 2019 4:46pm
geoffsnook
My supercharged has a lpg system and a lube kit and runs with no issues that i am aware of Thumbs Up
Post #572402 Fri Jan 04 2019 6:21pm
Mart
Are you getting any faults coming up on dash when u running LPG ?? Just summat I've seen on other forum
Post #572428 Fri Jan 04 2019 9:46pm
Themoog
United Kingdom 2005 Range Rover Sport Supercharged Rimini Red
I have a SC with lpg / lube kit also. Runs OK. No dash lights.
Have had to have alternator, ac condenser, coolant temp sensor and intercooler rad repaired in the last 10 months tho..
Lovely to drive tho. I wouldn't have a diesel car ever.
Post #572431 Fri Jan 04 2019 10:24pm
geoffsnook
No faults now but was getting the P0172 P0171 code but found that to be the oil filler cap not sitting on properly on mine and i think that's the most common fault that shows which is lean bank 1 and 2 Thumbs Up
Post #572451 Sat Jan 05 2019 2:04pm
geoffsnook
The early ones can also have the aux pump for the supercharger wired the wrong way round so the pump actually runs back wards but easy enough to change the pump yourself and costs about £100-120 for the pump that puts it into limp mode when the spirited driving mode starts which is quite often lol Thumbs Up
Post #572452 Sat Jan 05 2019 2:07pm
yeah the lean/rich codes codes can occur without LPG
Post #572454 Sat Jan 05 2019 3:08pm
geoffsnook
Yeah but quite surprised that it was so simple on mine to get rid of the codes but took a while to find
Post #572456 Sat Jan 05 2019 3:40pm
