![]() | Home > General > RRS 3.6 V8 diesel or 4.4 V8 petrol ?? |
I have the supercharged petrol engine so i am biased but as far as i am aware they are more reliable but still have a few issues |
4.2SC.
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I'm biased too!
I think you’re limiting your self to the oldest RRS when looking at the 4.4, at least if you look st the 4.2 you can buy a car that at its youngest could be 10 years old.
Mart Member Since: 03 Jan 2019 Location: Sheffield Posts: 15 ![]() ![]() |
Wouldn't it be cheaper to fix 4.4 one on 4.2 supercharger itself cost 400+ ... Don't mind repairs but don't want to put fortune into it all the time , and if it runs fine I might think of converting it to LPG but that's a long term , in there any 4.2 running LPG here ?? |
SC are fairly reliable though.
I have the 3.6 V8 and as brit plummer says, turbo's are an expensive item,,, I'm keeping my fingers crossed!. Most other things are par for the course no matter what model you get,,, front arms, wheel bearings, brakes. 2010 RRS, TDV8
My supercharged has a lpg system and a lube kit and runs with no issues that i am aware of |
Are you getting any faults coming up on dash when u running LPG ?? Just summat I've seen on other forum |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
I have a SC with lpg / lube kit also. Runs OK. No dash lights.
No faults now but was getting the P0172 P0171 code but found that to be the oil filler cap not sitting on properly on mine and i think that's the most common fault that shows which is lean bank 1 and 2 |
The early ones can also have the aux pump for the supercharger wired the wrong way round so the pump actually runs back wards but easy enough to change the pump yourself and costs about £100-120 for the pump that puts it into limp mode when the spirited driving mode starts which is quite often lol |
yeah the lean/rich codes codes can occur without LPG |
Yeah but quite surprised that it was so simple on mine to get rid of the codes but took a while to find |
