![]() | Home > General (L494) > L494 Oil Change |
MBRRS,did you run the engine first to get the oil hot as it comes out a lot easier than when its cold,unless their wasn't much oil it to start with. Andy.
MBRRS Member Since: 03 May 2019 Location: Hertfordshire Posts: 29 ![]() ![]() ![]() |
I only ran it for like 10 seconds The name’s Bond ‘ James Bond’ |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
My vacuum extractor came with a heavy rubber joiner which was a tight fit over the outside of drain tube on the car and was designed to seal against the tube from the extractor. Drains the full sump volume easily. My extractor is one designed for draining boat sumps and works well. (You cant get a sump drain pan under the engine in most inboard boats as its in the bilge, that's why a boat equipment shop is the best place to get a good one.) Should be done with the engine oil warmed up.
jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1909 ![]() ![]() |
+1 |
So it just goes over the pipe not inside the extraction hole ??? The name’s Bond ‘ James Bond’ |
Bardley Member Since: 26 Jul 2018 Location: Herts Posts: 150 ![]() ![]() |
Yes...OVER.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5122 ![]() ![]() ![]() |
Hi Col your image is a bit confusing as I’m seeing a purple pipe going inside the extraction pipe. The name’s Bond ‘ James Bond’ |
The small part (303-1484-1) is a adaptor which fits on to the end of the engine oil extraction tube fitted in the engine, then the suction pipe (303-1484) fits on to the adaptor, the illustration is taken from the L/R workshop manual and the numbers are those of the actual L/R kit for doing the job, if you google the numbers probably bring up pictures of the complete kit so you could see better.
Oh cheers Col so I should be able to just put my plastic rubber end over
As long as it seals o.k. shouldn't be a problem.
