![]() | Home > General (L494) > L494 Oil Change |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 ![]() ![]() |
I have the SVD8 and the extraction pipe is in front of the oil filler cap. I am still unsure how to remove the cap though as it turns and raises 1/2 inch but does not come free.
Coedlan Member Since: 30 Sep 2016 Location: N. Wales Posts: 71 ![]() ![]() |
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
Coedlan - I did the same thing at the weekend - only 4K after last service as a precaution, as I believe when I bought it, the car had done lots of cold starts and very short journeys/test drives - it was on the garage's forecourt for 5 months as they had overpriced it!
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Yes that's the one, I have done it a couple of times without any issues. Make sure that you don't accidentally over fill. If you do when you check the oil level on the dash readout then suck a bit out!
Thanks Guys I have now been able to remove, just needed more force. Tracking down suction equipment now and I am ready to do intermediate changes. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
RESULT !
Go to a boat equipment shop to get oil extraction kit as its usual on an inboard boat to extract the oil from the dip stick tube as you can't drain from the sump plug in the bottom of the bilge.
Thats the same as I use.
There is an Australian V6 diesel owner with over 260,000 on the clock and no issues. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
I think the oil they use is Castrol Edge 5w-30. MY16 RRS 3.0 SDV6 HSE Dynamic |
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
Castrol Edge Professional. Which is probably the same stuff with a different name, but a bit harder to get hold of and more expensive. RRS MY17 SDV6 AB
They are identical spec wise, AFAIK.
Bought the Edge professional on-line, came from Lancaster VW, cost £25 for 5 litres, I bought 25 litres, free delivery byFedex
