Home > General (L494) > L494 Oil Change
Page 3 of 3 <123
MBRRS
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Java Black
How did you put the pipe on the extraction tube put it over or put the tube inside as I tried this ( put it over ) and it only
Sucked up a small amount. I gave up then. The name’s Bond ‘ James Bond’
Post #582150 Mon Jun 10 2019 8:05am
Tyrefitter
MBRRS,did you run the engine first to get the oil hot as it comes out a lot easier than when its cold,unless their wasn't much oil it to start with. Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #582153 Mon Jun 10 2019 8:31am
MBRRS
I only ran it for like 10 seconds The name’s Bond ‘ James Bond’
Post #582154 Mon Jun 10 2019 8:33am
Barryp
Australia 2013 Range Rover Sport 3.0 TDV6 SE Fuji White
My vacuum extractor came with a heavy rubber joiner which was a tight fit over the outside of drain tube on the car and was designed to seal against the tube from the extractor. Drains the full sump volume easily. My extractor is one designed for draining boat sumps and works well. (You cant get a sump drain pan under the engine in most inboard boats as its in the bilge, that's why a boat equipment shop is the best place to get a good one.) Should be done with the engine oil warmed up.
Barry 2017 Range Rover Sport TDV6 L494 SE Fuji White
2011 Range Rover Sport SDV6 L320 SE Fuji White Loved but GONE
2010 TRAKKA Motorhome Fiat Ducato GONE (What a dud, don't buy one)
2006 Discovery 3 SE TDV6 Automatic Chawton White/Ebony. Loved but GONE
2006 BMW X5 diesel White/Charcoal, Bought new, Gone after 12 years! Was Excellent.
Ex Member Range Rover Club NSW
Post #582155 Mon Jun 10 2019 8:33am
jimbg
+1 Thumbs Up 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #582163 Mon Jun 10 2019 11:55am
MBRRS
So it just goes over the pipe not inside the extraction hole ??? The name’s Bond ‘ James Bond’
Post #582164 Mon Jun 10 2019 12:06pm
Bardley
Yes...OVER.
The tube fitted on the engine is the extractor pipe. 2011 MY D4 HSE
Previously 2001 D2 TD5, 1996 D1 300Tdi, 1985 90 2.2 petrol.
Bikes! KTM, BMW, British, Classics and others.
Post #582165 Mon Jun 10 2019 12:07pm
Post #582199 Mon Jun 10 2019 10:51pm
MBRRS
Hi Col your image is a bit confusing as I’m seeing a purple pipe going inside the extraction pipe. The name’s Bond ‘ James Bond’
Post #582200 Tue Jun 11 2019 4:14am
The small part (303-1484-1) is a adaptor which fits on to the end of the engine oil extraction tube fitted in the engine, then the suction pipe (303-1484) fits on to the adaptor, the illustration is taken from the L/R workshop manual and the numbers are those of the actual L/R kit for doing the job, if you google the numbers probably bring up pictures of the complete kit so you could see better.
Post #582201 Tue Jun 11 2019 4:37am
MBRRS
Oh cheers Col so I should be able to just put my plastic rubber end over
The pipe and be ok The name’s Bond ‘ James Bond’
Post #582202 Tue Jun 11 2019 4:43am
As long as it seals o.k. shouldn't be a problem.
Post #582203 Tue Jun 11 2019 4:51am
Page 3 of 3 <123
