Home > My Range Rover Sport > thumping sound
camarados
Netherlands 2007 Range Rover Sport TDV8 HSE Orkney Grey
thumping sound
Good afternoon!
I have this issue..
1) When I drive, I hear a thumping sound. That comes from the rear axle, especially when I release the gas.
What can that be? Differential?
Can you easily get there to repair?
(sorry, didnt got in the right category.. )
Post #567238 Thu Oct 18 2018 4:21pm
Assuming it's not the wife locked in the boot Laughing , a rear knocking could be one of a number of suspension bushes / anti roll bar bushes or the rear prop shaft centre bearing. It might be something else too. When does it make the noise? Under acceleration? Under braking? When just driving along normally? 2012 SDV6 - it's missing a couple of cylinders
Post #567251 Thu Oct 18 2018 11:26pm
EssexRRS
Check your fuel tank. I used to get a thump (as distinct from a more precise knock), when pulling away and it turned out to be fuel slopping around in the tank. There was a fix that the dealer did which was a matting that stopped fuel moving so much.
Post #567263 Fri Oct 19 2018 11:27am
camarados
well its not the fueltank i suppose Smile
It makes the sound when I release the accelerator..
Post #567361 Sun Oct 21 2018 9:35am
Scrumpy
Just a thought but maybe you can rule it out if not.
There are some movable weight ballasts under each side of the rear of the car I believe.
Could it be these moving when you brake/release the gas? I seem to remember some older posts about this. 2016 RRS SVR Estoril Blue
Post #567402 Sun Oct 21 2018 7:45pm
