Home > My Range Rover Sport > thumping sound |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Assuming it's not the wife locked in the boot , a rear knocking could be one of a number of suspension bushes / anti roll bar bushes or the rear prop shaft centre bearing. It might be something else too. When does it make the noise? Under acceleration? Under braking? When just driving along normally? 2012 SDV6 - it's missing a couple of cylinders
Thu Oct 18 2018 10:26pm |
EssexRRS Member Since: 04 Jun 2018 Location: Essex Posts: 22 |
Check your fuel tank. I used to get a thump (as distinct from a more precise knock), when pulling away and it turned out to be fuel slopping around in the tank. There was a fix that the dealer did which was a matting that stopped fuel moving so much. |
Fri Oct 19 2018 10:27am |
camarados Member Since: 07 Jul 2018 Location: Glimmen Posts: 6 |
well its not the fueltank i suppose
Sun Oct 21 2018 8:35am |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Just a thought but maybe you can rule it out if not.
Sun Oct 21 2018 6:45pm |
