![]() | Home > General (L494) > Squeak when pressing brake pedal |
00by Member Since: 25 May 2018 Location: Northants Posts: 81 ![]() |
I took my previous Audi to the dealer and complained of a similar problem at this time of year.
Punkawallah Member Since: 04 Sep 2018 Location: Salisbury Posts: 159 ![]() ![]() ![]() |
I had similar issue - it was the small micro switch which probably operates the brake lights - you can just see if with a torch if you get your head down there. WD40 solved it! |
RRSCS Member Since: 07 Mar 2012 Location: Budapest Posts: 19 ![]() ![]() ![]() |
Thank you very much, both of you.
