Home > General (L494) > Squeak when pressing brake pedal
RRSCS
Hungary 2010 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi Everyone,
I have a 15MY RRS SDV8 (around 75K km) and have recently encountered a slight squeak (inside the cabin from the pedal area) when pressing the break pedal when putting the gear selector into D or R at the first time after start. It does this strange noise intermittently (not always) and only after leaving the car for a while, e.g. when parked during office hours and/or night. It does it once and never while driving. Has anyone experienced this thing already? My front discs and pads were changed a month ago and they said they did the proper procedure to let the air out from the system.
Any helpful idea is appreciated.
Thx
Post #567090 Tue Oct 16 2018 2:13pm
00by
I took my previous Audi to the dealer and complained of a similar problem at this time of year.
After a lot of head scratching I realised it was caused by using damp shoes and the two rubber surfaces squeaking...slightly embarrassing! Embarassed MY16 RRS 3.0 SDV6 HSE Dynamic
Post #567092 Tue Oct 16 2018 2:33pm
Punkawallah
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Adriatic Blue
I had similar issue - it was the small micro switch which probably operates the brake lights - you can just see if with a torch if you get your head down there. WD40 solved it!
Post #567097 Tue Oct 16 2018 3:21pm
RRSCS
Thank you very much, both of you.
@00by - it did it with different shoes on, but will pay attention Rolling with laughter Bow down
@Punkawallah - thx, will check it out and give a try, utterly appreciate your suggestion
Best,
Post #567101 Tue Oct 16 2018 4:00pm
