![]() | Home > Technical > RESTRICTED PERFORMANCE IN RRS 2010 |
Search on this forum for turbo actuator and split pipes 2019 5.0 SC SVA (Current)
Slim444 Member Since: 09 Nov 2015 Location: Huntingdon Posts: 200 ![]() ![]() ![]() |
I had exactly the same earlier this year, turned out to be the MAF sensor that had gone.
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
In my case it was a split inlet manifold causing restricted performance. So three replies to your post all suggesting actually a number of potential causes. You need to go to an indy or dealer and get the codes read. |
Aaron92 Member Since: 09 Oct 2018 Location: Kings Lynn Posts: 13 ![]() ![]() |
Do not just search forums pay to have it plugged in could be something as simple as water sensor in diesel filter without diagnostics your taking a stab in the dark you may get lucky but more likely not |
mlambton Member Since: 25 Aug 2014 Location: Axminster Posts: 7 ![]() ![]() ![]() |
I had exactly the same symptoms. I took it to my local Indy who drained the fuel housing (error suggested water in the fuel) but got the same fault code so changed out the fuel filter housing...time will tell |
Mafya Member Since: 05 May 2020 Location: Sheffield Posts: 46 ![]() ![]() ![]() |
Just had similar on my 2010 RRS TDV8. It was showing error code P023D Manifold absolute pressure- turbocharger/supercharger boost sensor correlation.
NavyAlbert Member Since: 18 Nov 2020 Location: Nebraska Posts: 1 ![]() ![]() |
I had the same thing a couple of days ago with my 2011 5.0L V8. The Restricted Performance Red triangle came on and I was down to about 5mph (no engine warning light though). I pulled over and left the engine running for about 5 mins (in case it wouldn't start again) and when I came to pull away, the performance came back but the lights changed to an orange triangle and the DSC and EBD lights came on with the message "Drive with Caution, Stability Programme offline" (or words to that effect). I switched the vehicle off for a few hours and when I came to turn it back on, all the lights/faults cleared and all is back to normal. The only difference was, the car and dropped to access height so I had to raise the suspension before driving off.
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Google Technical Bulletin LTB00445V3. Can have a lot of causes RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
TrafficMan Member Since: 01 Nov 2020 Location: Nottingham Posts: 8 ![]() ![]() ![]() |
Half way through replacing both of my inlet manifolds on a 2011 RR Sport 3Lt HSE.
