Home > Technical > RESTRICTED PERFORMANCE IN RRS 2010
mchaula
United Kingdom 2010 Range Rover Sport TDV6 HSE Siberian Silver
Hello Folks,
My RRS 2010 TDV6 3.0 has displayed waring RESTRICTED PERFOMANCE and the car start losing the power at some point it can not pull to its normal perfomance however at low speed it works fine but restricted at higher speed.
Can anyone sugguest what could be the fault
Thanks in advance.
Thanks,
Mashaka
Post #566958 Sun Oct 14 2018 7:01pm
Brit Plumber
Search on this forum for turbo actuator and split pipes 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #566975 Sun Oct 14 2018 8:57pm
Slim444
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I had exactly the same earlier this year, turned out to be the MAF sensor that had gone.
Got it changed under warranty. Forgot the exact price, but dealer told me it would have been over £400!!!!
Replaced one on my Scooby a few years ago, and it was a £95 genuine part and about 10 mins to fit. You can't see the eyes of the demon until him come callin'
Post #567019 Mon Oct 15 2018 2:46pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
In my case it was a split inlet manifold causing restricted performance. So three replies to your post all suggesting actually a number of potential causes. You need to go to an indy or dealer and get the codes read.
Post #567035 Mon Oct 15 2018 8:52pm
Aaron92
Do not just search forums pay to have it plugged in could be something as simple as water sensor in diesel filter without diagnostics your taking a stab in the dark you may get lucky but more likely not
Post #567045 Mon Oct 15 2018 9:47pm
mlambton
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
I had exactly the same symptoms. I took it to my local Indy who drained the fuel housing (error suggested water in the fuel) but got the same fault code so changed out the fuel filter housing...time will tell
Post #605850 Thu Oct 22 2020 6:30pm
Mafya
United Kingdom 2010 Range Rover Sport TDV8 HSE Lux Buckingham Blue
Just had similar on my 2010 RRS TDV8. It was showing error code P023D Manifold absolute pressure- turbocharger/supercharger boost sensor correlation.
I took engine cover off and saw traces of soot on drivers side so after looking further I discovered a cracked inlet manifold.
Bought a new one and some injector bolts from guy salmond for £430 in total and ordered some injector seals from Advancedfactors who unfortunately couldn’t get inlet manifold due to back order issue.
Has it fitted yesterday by a garage I have used for 15 years for a labour charge of £200.
Have your codes read and check your inlet manifolds for cracks using soapy water.
Post #605871 Fri Oct 23 2020 3:28am
NavyAlbert
United States
I had the same thing a couple of days ago with my 2011 5.0L V8. The Restricted Performance Red triangle came on and I was down to about 5mph (no engine warning light though). I pulled over and left the engine running for about 5 mins (in case it wouldn't start again) and when I came to pull away, the performance came back but the lights changed to an orange triangle and the DSC and EBD lights came on with the message "Drive with Caution, Stability Programme offline" (or words to that effect). I switched the vehicle off for a few hours and when I came to turn it back on, all the lights/faults cleared and all is back to normal. The only difference was, the car and dropped to access height so I had to raise the suspension before driving off.
There is also a whirring sound coming from the glovebox area (I am in the US so it's a LHD). Any ideas what this might be?
Post #606737 Wed Nov 18 2020 9:45pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
Re: RESTRICTED PERFORMANCE IN RRS 2010
mchaula wrote:
Hello Folks,
Thanks in advance.
Thanks,
Mashaka
Google Technical Bulletin LTB00445V3. Can have a lot of causes RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #606763 Thu Nov 19 2020 2:18pm
TrafficMan
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Lux Stornoway Grey
Half way through replacing both of my inlet manifolds on a 2011 RR Sport 3Lt HSE.
Does anyone know if I have to remove both EGR Valves to enable me to remove both fuel rails ??
Any help much appreciated.
Thanks
Paul
Post #613882 Fri May 21 2021 5:55pm
