![]() | Home > Wheels & Tyres > 18" wheels with MY10 RRS |
Hi Kevin,to be honest I don’t think 18’s will clear the front calipers,some 19’s also don’t clear.The only 19’s that clear are certain LR Oe wheels
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 ![]() ![]() ![]() |
Compomotive PD1881 is your best choice https://www.comp.co.uk/products/product.asp?item=pd1881-30-229 |
kevin-h Member Since: 05 Nov 2010 Location: France Posts: 7 ![]() ![]() |
thank you rangemogger.
thank you tyrefitter,
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
18`s would look comical on a RR. Steve. |
Diversurfer Member Since: 24 Mar 2018 Location: Bragança Posts: 19 ![]() ![]() ![]() |
Hi Kevin-h,
They actually dont look to bad did think they would look s??t but they dont |
I use BFG 265/60 R18 AT KO2 , great tyre , no too much noise , good all around grip and a proper sidewall ...now I don´t have fear to potholes , kerbs , roots , etc...They are lighter and stronger than stock (rim and tyre combo too)
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 474 ![]() ![]() |
On the 2010 RRS you should be using
You can change the tire diameter with IID tool and the speedo will read has per normal, around 5 kph more then the GPS.
Lots of very interesting information here, thanks guys.
Father Jack Member Since: 16 Oct 2016 Location: Edinburgh Posts: 480 ![]() ![]() ![]() |
What is the purpose or benefit of changing to 18 inch ? Does it for example improve ride (which is excellent on 20 inch anyway) ?
You know it does father jack |
