Home > Wheels & Tyres > 18" wheels with MY10 RRS
kevin-h
2005 Range Rover Sport TDV6 HSE Zambezi Silver
Hello all,
I have a 2009 (MY10) RRS 3.0 TDV6.
It currently has 20" wheels (275/40/20 tyres) and I previously had an older model RRS with 19" wheels (255/50/19) so know that will fit.
I am contemplating putting 18" wheel on it and want to check the best tyre size.
Does Land Rover recommend a particular profile on this size?
Has anyone put 18" wheels on an RRS and if so, what tyre size did you run? I am thinking specifically for winter tyres, so a thinner profile would probably be preferable in my case.
Kevin.
Post #565980 Fri Sep 28 2018 3:15pm
Tyrefitter
Hi Kevin,to be honest I don’t think 18’s will clear the front calipers,some 19’s also don’t clear.The only 19’s that clear are certain LR Oe wheels
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #565984 Fri Sep 28 2018 4:33pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
Compomotive PD1881 is your best choice https://www.comp.co.uk/products/product.asp?item=pd1881-30-229
Post #565986 Fri Sep 28 2018 5:37pm
kevin-h
thank you rangemogger.
it looks like the offset is 44 but i think its 53 for my wheels.
what tyres would you run on the compomotive wheels?
Post #566004 Fri Sep 28 2018 11:47pm
kevin-h
thank you tyrefitter,
based on your name i assume you know what you are talking about.
i may just go with 19" wheels.
Post #566005 Fri Sep 28 2018 11:52pm
Cymruambyth
Wales
18`s would look comical on a RR. Steve.
Post #566006 Sat Sep 29 2018 12:03am
Diversurfer
Portugal 2007 Range Rover Sport TDV6 HSE Orkney Grey
Hi Kevin-h,
I recently changed the 20" rims and the same size tyres to the LR 18" inch rims and BFG 265/60R18.
After a lot of reading and talking with some people that went the same path, if you have Brembos you need the Compomotive rims.
I have the normal brakes so i could go with a second hand ones.
With the 265/60R18 you don't have to modify anything, no rubbing at any height and the spare fits inflated without any mods required.
Have a look at these guys:
https://www.voguexpeditions.com/ They are on instagram too.
or
https://www.greenovalexperience.com/
Very good write up in this post
https://www.aulro.com/afvb/l319-discovery-...4-rrs.html
This is mine with 18" and BFG's
Antonio
Post #566080 Sun Sep 30 2018 11:35am
geoffsnook
They actually dont look to bad did think they would look s??t but they dont Thumbs Up
Post #566083 Sun Sep 30 2018 2:07pm
rangemogger
I use BFG 265/60 R18 AT KO2 , great tyre , no too much noise , good all around grip and a proper sidewall ...now I don´t have fear to potholes , kerbs , roots , etc...They are lighter and stronger than stock (rim and tyre combo too)
By the way , my tyres are extrem snow rated
Post #566092 Sun Sep 30 2018 7:30pm
Autobiography1969
On the 2010 RRS you should be using
245/55/18 As a direct replacement for the standard 275/40/20
This is only +1 1 revolution per mile out
as opposed to 265/60/18 being 43 less with this oversized wheel & tyre combination..
https://tiresize.com/comparison/
Post #566093 Sun Sep 30 2018 8:10pm
Diversurfer
You can change the tire diameter with IID tool and the speedo will read has per normal, around 5 kph more then the GPS.
LR does not have the 265/60 legal in Portugal so i had to get them engineered.
There are people running 265/65 R18 but some have experienced some rubbing and the plastic in the spare wheel spot needs to come out or deflate the tire to fit.
IMO 13mm difference is not worth the hassle.
As rangemogger said BFG very quiet and a good all round tire.
You can go bigger but you need lift rods.
Post #566101 Mon Oct 01 2018 3:35am
kevin-h
Lots of very interesting information here, thanks guys.
I shall have to look into the BFG tyres.
Post #566102 Mon Oct 01 2018 6:01am
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
What is the purpose or benefit of changing to 18 inch ? Does it for example improve ride (which is excellent on 20 inch anyway) ?
Do those 2 inches really make a difference ? Smile
Post #566106 Mon Oct 01 2018 8:26am
geoffsnook
You know it does father jack Rolling with laughter Rolling with laughter
Post #566107 Mon Oct 01 2018 8:54am
Father Jack
Mr. Green Thumbs Up Mr. Green
Twisted Evil Twisted Evil Twisted Evil
Post #566112 Mon Oct 01 2018 10:23am
