Home > Wheels & Tyres > 18" wheels with MY10 RRS |
Hi Kevin,to be honest I don’t think 18’s will clear the front calipers,some 19’s also don’t clear.The only 19’s that clear are certain LR Oe wheels
Fri Sep 28 2018 4:33pm |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 |
Compomotive PD1881 is your best choice https://www.comp.co.uk/products/product.asp?item=pd1881-30-229 |
Fri Sep 28 2018 5:37pm |
kevin-h Member Since: 05 Nov 2010 Location: France Posts: 7 |
thank you rangemogger.
Fri Sep 28 2018 11:47pm |
thank you tyrefitter,
Fri Sep 28 2018 11:52pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
18`s would look comical on a RR. Steve. |
Sat Sep 29 2018 12:03am |
Diversurfer Member Since: 24 Mar 2018 Location: Bragança Posts: 19 |
Hi Kevin-h,
Sun Sep 30 2018 11:35am |
They actually dont look to bad did think they would look s??t but they dont |
Sun Sep 30 2018 2:07pm |
I use BFG 265/60 R18 AT KO2 , great tyre , no too much noise , good all around grip and a proper sidewall ...now I don´t have fear to potholes , kerbs , roots , etc...They are lighter and stronger than stock (rim and tyre combo too)
Sun Sep 30 2018 7:30pm |
Autobiography1969 Member Since: 17 Sep 2018 Location: S/E Posts: 472 |
On the 2010 RRS you should be using
Sun Sep 30 2018 8:10pm |
You can change the tire diameter with IID tool and the speedo will read has per normal, around 5 kph more then the GPS.
Mon Oct 01 2018 3:35am |
Lots of very interesting information here, thanks guys.
Mon Oct 01 2018 6:01am |
What is the purpose or benefit of changing to 18 inch ? Does it for example improve ride (which is excellent on 20 inch anyway) ?
Mon Oct 01 2018 8:26am |
You know it does father jack |
Mon Oct 01 2018 8:54am |
Mon Oct 01 2018 10:23am |
