Home > Maintenance & Modifications > RR sport sc 2005 start / turn over issue
Paulo 61
England 2005 Range Rover Sport Supercharged Java Black
Hi all,
Have an issue with my 2005 RR sport sc, when I turn the key to start it dose its checks but doesn't always turn over first time I have to turn key back then retry sometimes two or three times, It has always started and when it turns over it is at a good rate. Will check battery connection tomorrow but I don't think it is that as when it dose it the lights on the dash don't show signs of dimming ,
Wondered if anybody had come across this before.
Thanks
Paulo
Post #565175 Fri Sep 14 2018 8:57pm
Change relay by battery marked SM
Could use the rear blower relay if it's the same
Post #565176 Fri Sep 14 2018 9:45pm
Paulo 61
Thanks Andy I will give that a try and let you know how I get on Thumbs Up
Post #565191 Sat Sep 15 2018 9:01am
Paulo 61
Update was out for most of the day but when I got back had a look at the RR. Checked battery connections found the positive was not as tight as it should be. Then I changed the starter relay over with another one which was the same. Neither of these things sorted the problem. I suppose the next thing is the starter motor or the ignition switch ,problem is it doesn't do it every time.
Post #565283 Sun Sep 16 2018 7:26pm
Paulo 61
Hi all,
Quick update on RR, typically the starter has been turning over first time every time since We spoke last, removed head light and cleaned both earth connections , checked with multimeter battery pos to engine bracket getting reading of 12.32 which I'm guessing is a bit low , could that cause the problem ? It is a new battery but before I had the car I'm not sure it was used regularly
Post #566028 Sat Sep 29 2018 12:46pm
swatkins
United Kingdom 2005 Range Rover Sport Supercharged Siberian Silver
Also have a 2005 SC had the same was starter motor couple of months ago time to change it out ?
Post #566030 Sat Sep 29 2018 1:20pm
Paulo 61
Update, took battery off and charged for 24 hours re tested all good , not missed a beat since. I think a not quite fully charged battery can throw up all sorts on these RR Thumbs Up
Post #567108 Tue Oct 16 2018 6:27pm
