![]() | Home > Maintenance & Modifications > RR sport sc 2005 start / turn over issue |
Change relay by battery marked SM
Paulo 61 Member Since: 25 Aug 2018 Location: Southend on sea Posts: 13 ![]() ![]() ![]() |
Thanks Andy I will give that a try and let you know how I get on |
Update was out for most of the day but when I got back had a look at the RR. Checked battery connections found the positive was not as tight as it should be. Then I changed the starter relay over with another one which was the same. Neither of these things sorted the problem. I suppose the next thing is the starter motor or the ignition switch ,problem is it doesn't do it every time. |
Hi all,
swatkins Member Since: 01 Apr 2017 Location: Essex Posts: 57 ![]() ![]() ![]() |
Also have a 2005 SC had the same was starter motor couple of months ago time to change it out ? |
Update, took battery off and charged for 24 hours re tested all good , not missed a beat since. I think a not quite fully charged battery can throw up all sorts on these RR |
