Home > In Car Electronics > Tracker causing static pops and crackles ??
ab601
Since I picked up my p400e Hybrid RRS I have had problems with interference on the audio. I get clicks and pops like static across all sources most of the time. The car has been back to the dealers 5 times. On the last visit they replaced the lower digital screen but I still get the interference. Could it be the fitted trackstar tracker causing it ? Thinking of arranging to have it disconnected to see if it makes a difference. 2018 Range Rover Sport P400e Autobiography
Post #564717 Fri Sep 07 2018 4:08pm
Meiang
I had a similar problem with my 2010 TDV8 about 2 years ago. Every now and then I would get very loud clicks and pops from all speakers even when the audio system was turned off. The noise produced was so loud that it was painfull to the ears. The remedy was to turn the ignition off and leave it for an hour or so. If I restrated the car straight away the problem was still there. The problem has not resurfaced for the last 12 months or so. My local dealer could not diagnose the problem.
My car has the HK logic 7 system and rear seat entertainment system.
Post #564743 Sat Sep 08 2018 5:21am
james5599
My2017 does this periodically. It’s annoying when it does happen! 2019 Svr and 2019 R35 GTR
Post #564746 Sat Sep 08 2018 6:28am
ab601
It isn't very loud, it is just a faint crackle but very annoying, all the same. If it turns out not to be the tracker then I will be handing the vehicle back. 2018 Range Rover Sport P400e Autobiography
Post #564751 Sat Sep 08 2018 7:32am
