Home > In Car Electronics > Tracker causing static pops and crackles ?? |
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 |
I had a similar problem with my 2010 TDV8 about 2 years ago. Every now and then I would get very loud clicks and pops from all speakers even when the audio system was turned off. The noise produced was so loud that it was painfull to the ears. The remedy was to turn the ignition off and leave it for an hour or so. If I restrated the car straight away the problem was still there. The problem has not resurfaced for the last 12 months or so. My local dealer could not diagnose the problem.
Sat Sep 08 2018 5:21am |
james5599 Member Since: 14 Jun 2009 Location: london Posts: 325 |
My2017 does this periodically. It’s annoying when it does happen! 2019 Svr and 2019 R35 GTR |
Sat Sep 08 2018 6:28am |
ab601 Member Since: 08 Oct 2017 Location: Manchester Posts: 51 |
It isn't very loud, it is just a faint crackle but very annoying, all the same. If it turns out not to be the tracker then I will be handing the vehicle back. 2018 Range Rover Sport P400e Autobiography |
Sat Sep 08 2018 7:32am |
