Home > General > Roof spoiler flew off the M40 - Help needed please! |
Shez1878 Member Since: 06 May 2016 Location: Solihull Posts: 37 |
Sat Aug 18 2018 5:24pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
Checked out eBay ? |
Sat Aug 18 2018 5:53pm |
Yes, found a couple by 'Hawke' but again says for 2010 model and mine is 2009..... |
Sat Aug 18 2018 5:55pm |
I was thinking second hand painted your colour |
Sat Aug 18 2018 6:26pm |
Only seen brand new ones which I'm fine with, just dont know if they will fit! |
Sat Aug 18 2018 6:28pm |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
I may be wrong here, but if it's the face lift model it is a MY (model year) 2010, even if it's registered in 2009? |
Sat Aug 18 2018 6:45pm |
I’m hoping that is the case.... |
Sat Aug 18 2018 6:55pm |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
Thats correct, my car is a sept 2011 build but is a 2012 model year. Yours is probably a 59 plate 2010 model year?
Sat Aug 18 2018 7:17pm |
You legends, thank you!
Sat Aug 18 2018 7:21pm |
I’m thinking this one?
Sat Aug 18 2018 7:22pm |
That says it’s a 2010 style but it fits the 05 to 09 car so could be a different fit. 2019 5.0 SC SVA (Current)
Sat Aug 18 2018 10:23pm |
Contact this breaker and see if the spoiler is still available. Genuine Range Rover and hopefully the same colour as your car saving on the cost of painting!!
Sat Aug 18 2018 10:27pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
The genuine rear spoiler from a 2005-2009 will not fit a 2010-2013 car, although physically similar shape the two outer rear mounting points are in a different position, in addition to the rear brake lamp as well, the only way to get it to fit is also change the rear tailgate/glass hinges from either model depending on if you are going late model to early or visa versa.
Sat Aug 18 2018 10:54pm |
