Home > General > Roof spoiler flew off the M40 - Help needed please!
Shez1878
Hi Everyone,
As per the title, the roof spoiler on the back of my 2009 Range Rover Sport flew off the back on the M40 yesterday. To say I was shocked was an understatement! Owned the car for almost 2 years, never had a problem and then this. I have never owned a Range before and now I'm totally lost.
The car is a 59 plate facelift model. This is causing mass confusion, as when I search for a replacement part, I can see what I think is the right part but the description says it will fit 2010 only.
The top part of the spoiler has gone, the bottom part, braking light and parking camera are still in place.
I'm in desperate need of help as I genuinely have no idea what to do and am not willing to pay Land Rover £800 for a bit of plastic Sad
Post #563435 Sat Aug 18 2018 5:15pm
Shez1878
Post #563438 Sat Aug 18 2018 5:24pm
Shez1878
Post #563439 Sat Aug 18 2018 5:24pm
Checked out eBay ?
Post #563441 Sat Aug 18 2018 5:53pm
Shez1878
Yes, found a couple by 'Hawke' but again says for 2010 model and mine is 2009.....
Post #563442 Sat Aug 18 2018 5:55pm
I was thinking second hand painted your colour
Post #563448 Sat Aug 18 2018 6:26pm
Shez1878
Only seen brand new ones which I'm fine with, just dont know if they will fit!
Post #563449 Sat Aug 18 2018 6:28pm
Oldandconfused
I may be wrong here, but if it's the face lift model it is a MY (model year) 2010, even if it's registered in 2009?
Post #563451 Sat Aug 18 2018 6:45pm
Shez1878
I’m hoping that is the case....
Post #563452 Sat Aug 18 2018 6:55pm
Brit Plumber
Thats correct, my car is a sept 2011 build but is a 2012 model year. Yours is probably a 59 plate 2010 model year?
If you need a complete new spoiler I’d be tempted with a Autobiography style. The painting probably won’t be cheap either! 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #563453 Sat Aug 18 2018 7:17pm
Shez1878
You legends, thank you!
Any advice on how much I’ll need to spend and where to get a replacement from?
Post #563454 Sat Aug 18 2018 7:21pm
Shez1878
I’m thinking this one?
https://rover.ebay.com/rover/0/0/0?mpre=ht...1444863356
Post #563455 Sat Aug 18 2018 7:22pm
Brit Plumber
That says it’s a 2010 style but it fits the 05 to 09 car so could be a different fit. 2019 5.0 SC SVA (Current)
Post #563466 Sat Aug 18 2018 10:23pm
Brit Plumber
Contact this breaker and see if the spoiler is still available. Genuine Range Rover and hopefully the same colour as your car saving on the cost of painting!!
https://m.ebay.co.uk/itm/RANGE-ROVER-SPORT...SwQFJaxTHN 2019 5.0 SC SVA (Current)
Post #563467 Sat Aug 18 2018 10:27pm
The genuine rear spoiler from a 2005-2009 will not fit a 2010-2013 car, although physically similar shape the two outer rear mounting points are in a different position, in addition to the rear brake lamp as well, the only way to get it to fit is also change the rear tailgate/glass hinges from either model depending on if you are going late model to early or visa versa.
Post #563469 Sat Aug 18 2018 10:54pm
