![]() | Home > General > 2.7 TDV6 HSE vs 3.6 TDV8 HSE spec differences |
Calcifur Member Since: 21 Jun 2018 Location: Scotland Posts: 37 ![]() ![]() |
To be hoenst I will do as much servicing as I can myself. where I live, in the NE of Scotland I have 2 options for Main dealers. Petervardy Land Rover Jag in Aberdeen, and although my girlfriends sister works there, I wouldn't buy a cup of coffee from Peter Vardy after all teh problems haad with there 'service' department in the past, and cuz its Aberdeen they think we all have £100 notes falling out out our pockets
quick question regarding the list of standard items on the TDV8 HSE. It looks like adaptive cruise is a standard item, so should be present on all TDV8 HSE is that correct?
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Not sure if all TDV8's had it mine certainly did, have a look at the steering wheel, if it actualy has it will have extra switch at side by cruise control buttons.
Hi, yeah that's what I did, the wheel only has the normal cruise buttons, so it's not fitted. Was just a little confused as I thought is was a standard item at HSE level. Maybe not.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
All pre-facelift TDV8s got adaptive cruise in the UK, I think. Perhaps it's had the wheel changed and someone's put the wrong wheel on? 2012 SDV6 - it's missing a couple of cylinders
This is the advert
That's not a TDV8. If you look at the service pages you can see it says "RANGE ROVER SPT TDV6 SE". TDV8s were all HSE (or possibly HST)
Man you have keen eyes! Although thank you for confirming what I suspected. Someone is at it!! |
i agree no under bonnet pics and the service pages are for a 2.7 se so not the same car me thinks |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
rear wiper is parked on the wrong side too |
Quick look on google and I can see no reference to 3.6 TDV6. 2.7TDV6, 3.0TDV6 and 3.6 TDV8 only.
Would that not cost them a fortune to put a 3.6 in to a 2.7 lol |
Hence me saying they only changed part of the logbook following an engine change. If you had a broken 2.7 engine, and knew someone with a cheap/written off v8 going on your door step, I guess it made sence |
Either way, good luck getting it insured if its not what the log book says it is! |
