Home > General > 2.7 TDV6 HSE vs 3.6 TDV8 HSE spec differences |
Calcifur Member Since: 21 Jun 2018 Location: Scotland Posts: 37 |
To be hoenst I will do as much servicing as I can myself. where I live, in the NE of Scotland I have 2 options for Main dealers. Petervardy Land Rover Jag in Aberdeen, and although my girlfriends sister works there, I wouldn't buy a cup of coffee from Peter Vardy after all teh problems haad with there 'service' department in the past, and cuz its Aberdeen they think we all have £100 notes falling out out our pockets
Sun Jun 24 2018 8:13am |
quick question regarding the list of standard items on the TDV8 HSE. It looks like adaptive cruise is a standard item, so should be present on all TDV8 HSE is that correct?
Mon Jun 25 2018 7:34am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4992 |
Not sure if all TDV8's had it mine certainly did, have a look at the steering wheel, if it actualy has it will have extra switch at side by cruise control buttons.
Mon Jun 25 2018 7:38am |
Hi, yeah that's what I did, the wheel only has the normal cruise buttons, so it's not fitted. Was just a little confused as I thought is was a standard item at HSE level. Maybe not.
Mon Jun 25 2018 7:40am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8999 |
All pre-facelift TDV8s got adaptive cruise in the UK, I think. Perhaps it's had the wheel changed and someone's put the wrong wheel on? 2012 SDV6 - it's missing a couple of cylinders
Mon Jun 25 2018 8:10am |
This is the advert
Mon Jun 25 2018 8:32am |
That's not a TDV8. If you look at the service pages you can see it says "RANGE ROVER SPT TDV6 SE". TDV8s were all HSE (or possibly HST)
Mon Jun 25 2018 3:14pm |
Man you have keen eyes! Although thank you for confirming what I suspected. Someone is at it!! |
Mon Jun 25 2018 3:30pm |
i agree no under bonnet pics and the service pages are for a 2.7 se so not the same car me thinks |
Mon Jun 25 2018 4:59pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4981 |
rear wiper is parked on the wrong side too (broke?)
Mon Jun 25 2018 5:12pm |
Quick look on google and I can see no reference to 3.6 TDV6. 2.7TDV6, 3.0TDV6 and 3.6 TDV8 only.
Mon Jun 25 2018 5:45pm |
Would that not cost them a fortune to put a 3.6 in to a 2.7 lol |
Mon Jun 25 2018 5:48pm |
Hence me saying they only changed part of the logbook following an engine change. If you had a broken 2.7 engine, and knew someone with a cheap/written off v8 going on your door step, I guess it made sence |
Mon Jun 25 2018 6:02pm |
Either way, good luck getting it insured if its not what the log book says it is! |
Mon Jun 25 2018 6:42pm |
