Home > Technical > Oil pressure.
harrij
United Kingdom 2007 Range Rover Sport TDV6 SE Java Black
Oil pressure.
How long before your oil pressure light goes out from cold. My RR takes about 4 seconds and 1 second warm, about right?I also use an additive (slick 50). I realize all oil switches will vary slightly, O for the days of the old Jags when your dash was covered in dials. Regs JH
Post #559502 Thu Jun 21 2018 8:02am
yours being a 2007, you should get a new oil pump (as they have a weak cambelt tensioner mount) and new cambelt at the same time.
Bonus, you might improve the oil pressure.
Post #559504 Thu Jun 21 2018 8:25am
LandPhil
United Kingdom 2013 Range Rover Sport SDV6 HSE Ipanema Sand
Good idea to replace oil pump but don’t expect a dramatic improvement in oil pressure. Pumps produce flow rate, the condition of the engine, ie clearances, produce pressure. If your engine has low pressure that’s wear and tear.
Post #559511 Thu Jun 21 2018 10:10am
you know if the light is genuine or not, as you can hear and hydraulic lifters stop making a noise when the light goes out.
If the oil filter hasn't been fitted correctly, this can cause the oil to drain down, and delay the light going out.
New oil can also help sometimes
Post #559519 Thu Jun 21 2018 3:08pm
