Home > Technical > Oil pressure. |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4943 |
yours being a 2007, you should get a new oil pump (as they have a weak cambelt tensioner mount) and new cambelt at the same time.
Thu Jun 21 2018 8:25am |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 |
Good idea to replace oil pump but don’t expect a dramatic improvement in oil pressure. Pumps produce flow rate, the condition of the engine, ie clearances, produce pressure. If your engine has low pressure that’s wear and tear. |
Thu Jun 21 2018 10:10am |
you know if the light is genuine or not, as you can hear and hydraulic lifters stop making a noise when the light goes out.
Thu Jun 21 2018 3:08pm |
