Home > Off Topic - Other Cars > Ford GPW
Brit Plumber
Ford GPW
I’m at the point in the restoration of my Ford GPW of needing to look at either hiring, borrowing or buying a good quality spot welder. I know there’s a wealth of knowledge of all types on this board and I’m pretty confident someone here will know where I can hire a spot welder. Non of the usual hire places appear to have them but someone may know of a national chain or someone in the South Lincs area who hires them out. Any suggestions greatly appreciated. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #559412 Tue Jun 19 2018 10:30pm
PIG88
Does HSS in Lincoln have what you need? https://www.hss.com/hire/find-a-branch/eas...amp;brand=
Post #559413 Tue Jun 19 2018 10:38pm
Brit Plumber
Thanks for the reply, Unfortunately they don’t hire spot welders. I think I’ll end up buying one and then at least I can take my time over it. I just don’t know how good the Sealey/Clarke types are. I’ll only probably need to do 200 or so spots so it doesn’t need to be long lasting or even heavy duty. I have a 32amp supply so power isn’t a problem. 2019 5.0 SC SVA (Current)
Post #559469 Wed Jun 20 2018 7:36pm
PIG88
Anything helpful on this welding forum? http://www.ukwelder.com/forum/index.php?showforum=7
Post #559518 Thu Jun 21 2018 3:55pm
HughN
Wales
I think you should repair it with a 1942 spot-welder.... Laughing
Post #559530 Thu Jun 21 2018 7:22pm
