![]() | Home > Off Topic - Other Cars > Ford GPW |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
Does HSS in Lincoln have what you need? https://www.hss.com/hire/find-a-branch/eas...amp;brand= |
Thanks for the reply, Unfortunately they don’t hire spot welders. I think I’ll end up buying one and then at least I can take my time over it. I just don’t know how good the Sealey/Clarke types are. I’ll only probably need to do 200 or so spots so it doesn’t need to be long lasting or even heavy duty. I have a 32amp supply so power isn’t a problem. 2019 5.0 SC SVA (Current)
Anything helpful on this welding forum? http://www.ukwelder.com/forum/index.php?showforum=7 |
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
I think you should repair it with a 1942 spot-welder.... |
