Home > Faults & Fixes > Steering vibration at 70mph + and pulsing brake pedal |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I used to get the pulsing brake pedal without the steering vibration,, turned out to be a sticky caliper. I had the wheel vibration on a separate occasion and I found the front wheels were slightly oval,,, but you say you have new wheels. 2010 RRS, TDV8
Thu Aug 30 2018 6:37pm |
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 |
If the brake pedal moves it has be a problem with the brake pad, disc, hub , or an alignment issue with the hub, upright. Or brake pad carrier alignment sticking calliper / piston.
Thu Aug 30 2018 8:23pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Not sure what year your car is, i.e. when it was built, but early car steering racks could not even handle 20in rims, let alone 22inch.
Fri Aug 31 2018 12:36pm |
Look at TSB X3 Wheel Shimmy
Fri Aug 31 2018 12:40pm |
