Home > Technical > RRS 2010 TDV6 Engine System Fault |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Had this with a wonky remap...
Tue May 29 2018 6:07pm |
Had the same thing with a tuning box on my disco3 but if i restarted it cleared the fault so binned the box |
Tue May 29 2018 6:30pm |
luckske Member Since: 30 May 2016 Location: Limburg Posts: 33 |
I have the exact same problem - as soon as it is 32-33 degrees outside I get the engine fault and also read the same error code from the iidtool. I always get it whilst just driving along at 50~70km/h.
Wed May 30 2018 6:19am |
Chrisp75 Member Since: 09 May 2018 Location: Bromley Posts: 7 |
Hmmmm thanks. Will need to have a look under the hood to see if I can see anything that looks added. Any ideas typical location.
Wed May 30 2018 6:34am |
Yup that’s what happens to me too. Not had the car long so unsure about tuning etc but symptoms are the same. First time cleared straight away but when coming over to France was warm on mo day so despite a 15 minute stop the error came back pretty quickly. Can still get decent speed but as soon as you hit a hill you’re in trouble!!!!
Wed May 30 2018 6:41am |
Interestingly, I did several hours reasonably fast this morning no problems and then switched on cruise control and within minutes the problem occurred again.
Wed May 30 2018 10:47am |
You might be on to something. I remember that the last time I had the issue I was also driving with cruise control on - if it ever gets warm enough again, I'll try to see if using cruise control makes a difference. |
Thu May 31 2018 6:00am |
checked it on the snap on before I cleared the fault this morning, exactly the same message again,
Thu May 31 2018 1:39pm |
