Home > Technical > RRS 2010 TDV6 Engine System Fault
Chrisp75
Evening All,
Apologies if this has been posted about before or is in the wrong category. Was an active member on MBclub.co.uk but moved to an RRS now so am discovering the unique niceties of the car.
Anyway, I’ve had the above message twice, both whilst on the motorway and in pretty warm conditions and it’s resulted in reduced power until I switch off and let it cool down. I’m in France at the moment and it’s pretty warm on the way here so happened on the way which resulted in around 150km of pretty slow motoring. As I say I think both times it’s happened its been pretty hot so not sure if this comes into play anywhere.
Last time it happened I was in the UK and luckily my dad has a garage and I’ve got access to some SnapOn test gear which gave me a pretty general which was...
P062B - Internal Control Module Fuel Injector Control Performance.
When the faulty occurs I get the red warning triangle on the dash which even when the fault clears stays illuminated and warns me on switch on, which also to gets on my nerves!
Does anyone have any pointers or if not does anyone know a sensible specialist in South East London who may be able rectify without fobbing me off?
Many thanks and look forward to getting this solved as it’s a pretty frustrating problem.
Post #557680 Tue May 29 2018 5:24pm
Disco_Mikey
Had this with a wonky remap...
Worth checking first Thumbs Up
Post #557687 Tue May 29 2018 6:07pm
geoffsnook
Had the same thing with a tuning box on my disco3 but if i restarted it cleared the fault so binned the box Thumbs Up
Post #557692 Tue May 29 2018 6:30pm
luckske
Belgium 2010 Range Rover Sport 3.0 TDV6 HSE Ipanema Sand
I have the exact same problem - as soon as it is 32-33 degrees outside I get the engine fault and also read the same error code from the iidtool. I always get it whilst just driving along at 50~70km/h.
Sometimes waiting for 5 minutes is enough, but sometimes it would come back after a few minutes of driving. Haven't found a permanent solution unfortunately.
This is the error code I got from the iidtool:
P062B-00 (2F) Internal control module fuel injector control performance
I don't have a remap or tuning box, but I thought it might be related to the ECM overheating?
Post #557713 Wed May 30 2018 6:19am
Chrisp75
Hmmmm thanks. Will need to have a look under the hood to see if I can see anything that looks added. Any ideas typical location.
Chris
Post #557714 Wed May 30 2018 6:34am
Chrisp75
Yup that’s what happens to me too. Not had the car long so unsure about tuning etc but symptoms are the same. First time cleared straight away but when coming over to France was warm on mo day so despite a 15 minute stop the error came back pretty quickly. Can still get decent speed but as soon as you hit a hill you’re in trouble!!!!
It’s a pretty annoying gremlin.
Post #557715 Wed May 30 2018 6:41am
Chrisp75
Interestingly, I did several hours reasonably fast this morning no problems and then switched on cruise control and within minutes the problem occurred again.
I wonder if there is an unhappy map and it’s upsetting the cruise control computer.
Post #557726 Wed May 30 2018 10:47am
luckske
You might be on to something. I remember that the last time I had the issue I was also driving with cruise control on - if it ever gets warm enough again, I'll try to see if using cruise control makes a difference.
Post #557811 Thu May 31 2018 6:00am
Chrisp75
checked it on the snap on before I cleared the fault this morning, exactly the same message again,
P062B - internal control module Fuel injector control performance
Drove the rest of the way back from France without cruise and no problems whatsoever so maybe the answer is not to use cruise control........slightly angling as I use it quite a bit but not the end of the world I suppose.
Post #557842 Thu May 31 2018 1:39pm
