Home > Faults & Fixes > steering vibration |
Brit Plumber Member Since: 05 Jan 2018 Location: Sleaford, Lincolnshire Posts: 1849 |
I get a intermittent vibration through my steering wheel at the same speeds. Always seams to happen in the first 5 minutes of starting then goes away. I need to check my brakes and see if I’ve got one dragging a little. 2019 5.0 SC SVA (Current)
Mon May 21 2018 8:11pm |
dieselwoofer Member Since: 21 May 2018 Location: down south Posts: 23 |
It’s going back to the garage on weds as it’s still under warranty
Mon May 21 2018 10:13pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
So is this a 1980 RRS no car details so how can we help? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Mon May 21 2018 10:28pm |
I’ve just noticed that this new forum format has removed all my details. Is it just my screen that has this new format? 2019 5.0 SC SVA (Current)
Mon May 21 2018 10:46pm |
A screen shot of what I now see. And no obvious way to edit a post either.
Mon May 21 2018 10:48pm |
Same the mobile version is a bit basic. 2011 RRS facelift |
Tue May 22 2018 6:43am |
OK your model has the same brakes as mine I believe. I had a lot of issues of vibration on brake application which turned out to be the pad material used by Range rover, it seems in the flat land of Oz with little traffic the brakes would not get to he right temps and brake material would adhere to the rotors. I fixed by changing pads to Red Stuff pads, ECB I think. All good now. I also get some slight vibes first thing in when the outside temp is low, goes after a kilometer. I put this down to a standing flat spot in he tyres. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Tue May 22 2018 7:12am |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 |
make sure the tire pressures are correct - I had a similar issue at speed even after a wheel balancing, turned out the front left tire was down on pressure with the rest. |
Thu May 24 2018 9:12am |
Still going around in circles on this
Tue May 29 2018 2:10pm |
[quote="IRBails"][quote="Brit Plumber"]A screen shot of what I now see. And no obvious way to edit a post either.
Tue May 29 2018 2:11pm |
