Home > Maintenance & Modifications > Range Rover Sport 2012 - Dual DashCam Install
mrluke
Hi, spent an hour yesterday installing a dashcam to the front and rear of my RR . I used the Mini 0906 dashcam due to using it in a BMW X1 install and it seems a very good front and rear dashcam.
First was finding a fuse that goes on/off with the car ignition . I used the cigarette lighter fuse behind the passenger glove box ( the relay turns on and off the cigarrete lighter when the doors lock/unlocks .. so not quite an ignition live fuse but good enough).
Used a Fusetap and a USB/Multi Cigarette lighter adapter to power the camera and grounded on a chassis bolt. I have used hardwire kits before for the dashcam but had one damage a dashcam ! so now stick to fused cigarette adapters.
I pulled off the Door rubber trim and ran the cable inside , Poked the cable behind the windscreen pillar airbags and placed the camera in the middle.
The rear camera is powerd via a cable from the front camera , it also saves video to the front camera . I ran this cable on the drivers side of the car and poked behind all trim.
Rear camera placed , and clips used to tidy cables.
Post #554822 Mon Apr 23 2018 11:39am
Lindab
Fitted the 0906 dashcam to my RRS2 & connected it into the overhead light panel, saves running wires down the A pillar into the fusebox
Post #554836 Mon Apr 23 2018 1:00pm
I simply piggy backed off fuses 48 permanent live and 52 ignition live, never had an issue in 4 years.
Post #554837 Mon Apr 23 2018 1:12pm
mrluke
arnt you then sharing a fuse ? or did you up the fuse size ?
Post #555956 Mon May 07 2018 7:30pm
Father Jack
Its not too bad a job. Did same myself, cables easy to hide. Piggy back fuse holder onto 12v front socket so fires up on opening door and shuts off about 5 min after ignition off.
Post #556113 Thu May 10 2018 7:29am
Russben
If you are careful & lubricate the cable with WD40 / GT85 or similar you can feed the cable through the concertina 'bellows' that run from the body to the tailgate to make it a touch neater.
I used a stiff piece of wire and taped the rear dash-cam cable to it to pull it through the bellows. You just need to lower the rear of the headlining a small amount to access the end of the bellows. I'm in the shed, I'll be back in the real world in a minute.
Post #556517 Tue May 15 2018 4:22pm
Lindab
The dashcam only takes about 0.2amps so no need to worry about fuses blowing
Post #556629 Wed May 16 2018 3:53pm
Deleted
Post #556675 Wed May 16 2018 10:17pm
