Home > Maintenance & Modifications > Range Rover Sport 2012 - Dual DashCam Install |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 897 |
Fitted the 0906 dashcam to my RRS2 & connected it into the overhead light panel, saves running wires down the A pillar into the fusebox |
Mon Apr 23 2018 12:00pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
I simply piggy backed off fuses 48 permanent live and 52 ignition live, never had an issue in 4 years.
Mon Apr 23 2018 12:12pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
arnt you then sharing a fuse ? or did you up the fuse size ? |
Mon May 07 2018 6:30pm |
Its not too bad a job. Did same myself, cables easy to hide. Piggy back fuse holder onto 12v front socket so fires up on opening door and shuts off about 5 min after ignition off. |
Thu May 10 2018 6:29am |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 |
If you are careful & lubricate the cable with WD40 / GT85 or similar you can feed the cable through the concertina 'bellows' that run from the body to the tailgate to make it a touch neater.
Tue May 15 2018 3:22pm |
The dashcam only takes about 0.2amps so no need to worry about fuses blowing |
Wed May 16 2018 2:53pm |
Deleted |
Wed May 16 2018 9:17pm |
