Home > Maintenance & Modifications > Scuttle Panel Painting.
Lindab
Expensive & a lot of work replacing parts. Have a look at this using Gtechniq C4 & as I said before this will do all your plastic trim
Post #554627 Thu Apr 19 2018 9:43pm
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Re Scuttle Panel
Thanks Lindab
The only other problem I have is the Scuttle Panel has a whitey coating and is also has like green dried algae on it .Not sure if the GTECH would cover this.
Cheers Jock. Thumbs Up
Post #554678 Fri Apr 20 2018 8:19pm
Lindab
Jock, Here is a video from the Porsche forum (I have one of these also) which shows returning the scuttle panel to black using a heat gun. May be worth a go Shocked Suggest you clean the green algae with a nail brush.
Post #554681 Fri Apr 20 2018 9:35pm
The Heat Gun trick doesn't work all it does is cause the plastic to "leech" the colour back to the surface and after a time it will return to it's faded colour again. Have been doing that for years on to trucks just to tart them up a bit for the auctions or tests.
Fifty odd quid, 1/2 hour to fit and forget it for 3 years. Job Done.
Post #554683 Fri Apr 20 2018 9:59pm
Jock 77
Re Scuttle Panel
Cheers for all the replies lads. Thumbs Up
Post #554688 Sat Apr 21 2018 3:30am
Cymruambyth
Wales
Remember, before using something like G4...clean the area first using an APC and then some alcohol if you have some (Stella won`t do) to make sure the restorer adheres correctly Thumbs Up Steve.
Post #554697 Sat Apr 21 2018 10:09am
HN54AWS
England 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Just ordered some Gtechniq C4, £27 for 15ml off Ebay, hope this does the trick 😎
Post #554708 Sat Apr 21 2018 5:10pm
Jock 77
Re Scuttle Panel.
Cheers again for the replies. Thumbs Up
Post #554717 Sat Apr 21 2018 7:31pm
Socast
If you decide to replace the scuttle remember to buy new trim clips for the A pillar trims.
Also when removing the A pillar trim there are two locating pegs at the top and bottom of the trim, these have a habit of breaking off, not really an issue for the trim but they do leave a hole where water can enter and flood your foot wells. So if your trim is damaged then use some duct tape to cover the hole Thumbs Up
Post #554860 Mon Apr 23 2018 3:26pm
HughN
Wales
It is brilliant stuff. However... ...the one place I couldn't get it to have an effect was the scuttle panel. The C4 just disappeared into it like water into sand.
The other problem is that by the time it needs redoing I will have lost the little bottle!
Post #554871 Mon Apr 23 2018 5:46pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
I've just painted mine. Fed up of using various restorers to have to do it again a few months later. Used a product called 'Buzzweld Plastic In One' (as recommend3ed elsewhere on this site). Also decided to paint the rear tailgate release button, the front headlamp washers and the rear wiper arm.
Few points that might help:
To remove the scuttle you have to remove wiper arms. Your's may come off easily, mine did not.......tried tapping with hammer etc but then realised I needed a wiper arm puller. Probably worth getting one of these, about £12 or borrow one.
This style was useless, did not fit.....
Get one like this instead.....£11 in MachineMart..
To remove the headlamp washers there's a youtube video by Powerful UK (demo'd on a Disco3 but same setup).....they made it look easy, I had a bit of a faff....
To remove the tailgate release button, again, video from Powerful UK, easy.
A-pillar cover clips. I've read various posts detailing different part numbers etc for the clips required for the A pillar covers......I thought they'd be fine, so took a chance......broke all 6 of the white clips and 2 of the black clips....spoke to Landrover who offered to sell me a pack of 20 plastic clips for over £60!!!! Cheers!! I did some digging on here and found a part number for a complete pack, all the clips you require for both A-Pillar covers, for aboiut £12. These were the correct ones for my 2005 HSE.
The PIO stuff seems to be pretty good. I've hardly ever sprayed anything before, and other than a clean and rough up with some scotchbrite did no other prep, just sprayed srtraight on, about 4 coats. It's very forgiving and no runs. Think it was about £16. I'm pretty pleased with the result, hopefully it lasts.........
Before:
After:
My poor photography skills doesn't do the PIO justice, it actually looks really good...
Post #598893 Wed May 13 2020 10:02pm
HughN
Wales
Good job. Thumbs Up
Better to read this and buy a wiper-arm puller before starting!
Post #598911 Thu May 14 2020 12:56pm
