![]() | Home > Maintenance & Modifications > Automatic Transmission Fluid - Flush and Change |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5040 ![]() ![]() ![]() |
well worth doing on yours |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
Holy poop......that was manky |
I think black is the normal colour above 100K |
Wow looks like old chip oil |
^^^^^^ I`ve never seen chip oil that colour |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 ![]() ![]() ![]() |
The black oil was noticeably more viscous than the new stuff - and that was out of a car that had been driven to make progress for an hour so it was still warm and therefore more liquid than it would have been cold.
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 ![]() ![]() ![]() |
Hi map_rrs,
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
LR reckon the gearbox fluid is ok until 150k. Yours at 140k would suggest that they are wrong and the general wisdom that changes at half that mileage are a better proposition is correct. |
ATF Flush and and Replace - phone and web research suggests it's generally around £250 mark - I was offered and took the option for additives - to be honest I don't know what they are or what they do but they're in there and yes I got properly "up-sold" but the additional £30 seemed like a no-brainer to me. Transfer Case, Front and Rear Diffs - around £150. These prices include VAT - I might have been able to reduce the cost with a bit of haggling but sometimes the price reduction isn't worth it in terms of value now or in the future. Hope this helps - I do think it is good value assuming there aren't other pressing maintenance/safety works to be done. |
Absolutely. Am new to RRS but after many years driving, tracking and modding a Boxster I've learned that a forum's collective knowledge & experience or as you describe it "wisdom" is a pretty good guide to what should be done as opposed to mindlessly adhering to a manufacturer's recommendations/advice/schedule. |
Hi map_rrs, Thanks for the info, much appreciated! Regards, Danny |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 ![]() ![]() ![]() |
just had ours flushed on a 55 plate with 182 000 on clock, feels like a new car |
Hi Cupra,
mf175 Member Since: 06 May 2018 Location: Leeds Posts: 2 ![]() ![]() ![]() |
Is the transmission fluid easy enough to change at home over a pit. Has anyone done this work themselves on a TdV8 L320? If so please give a run down of what is involved. |
