Home > Maintenance & Modifications > Automatic Transmission Fluid - Flush and Change |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
well worth doing on yours |
Fri Apr 13 2018 10:34am |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
Holy poop......that was manky Steve. |
Fri Apr 13 2018 11:06am |
I think black is the normal colour above 100K |
Fri Apr 13 2018 11:25am |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Wow looks like old chip oil 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Apr 13 2018 11:46am |
^^^^^^ I`ve never seen chip oil that colour Steve. |
Fri Apr 13 2018 4:24pm |
map_rrs Member Since: 30 Jan 2018 Location: London Posts: 32 |
The black oil was noticeably more viscous than the new stuff - and that was out of a car that had been driven to make progress for an hour so it was still warm and therefore more liquid than it would have been cold.
Fri Apr 13 2018 10:45pm |
Danny1 Member Since: 25 Nov 2016 Location: Essex Posts: 61 |
Hi map_rrs,
Mon Apr 23 2018 8:03pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
LR reckon the gearbox fluid is ok until 150k. Yours at 140k would suggest that they are wrong and the general wisdom that changes at half that mileage are a better proposition is correct. 2012 SDV6 - it's missing a couple of cylinders
Mon Apr 23 2018 8:43pm |
ATF Flush and and Replace - phone and web research suggests it's generally around £250 mark - I was offered and took the option for additives - to be honest I don't know what they are or what they do but they're in there and yes I got properly "up-sold" but the additional £30 seemed like a no-brainer to me. Transfer Case, Front and Rear Diffs - around £150. These prices include VAT - I might have been able to reduce the cost with a bit of haggling but sometimes the price reduction isn't worth it in terms of value now or in the future. Hope this helps - I do think it is good value assuming there aren't other pressing maintenance/safety works to be done. |
Tue Apr 24 2018 4:44pm |
Absolutely. Am new to RRS but after many years driving, tracking and modding a Boxster I've learned that a forum's collective knowledge & experience or as you describe it "wisdom" is a pretty good guide to what should be done as opposed to mindlessly adhering to a manufacturer's recommendations/advice/schedule. |
Tue Apr 24 2018 4:55pm |
Hi map_rrs, Thanks for the info, much appreciated! Regards, Danny |
Thu Apr 26 2018 4:42pm |
Cupra Member Since: 20 Oct 2012 Location: Kent Posts: 81 |
just had ours flushed on a 55 plate with 182 000 on clock, feels like a new car |
Sun Apr 29 2018 6:18pm |
Hi Cupra,
Mon Apr 30 2018 7:58am |
mf175 Member Since: 06 May 2018 Location: Leeds Posts: 2 |
Is the transmission fluid easy enough to change at home over a pit. Has anyone done this work themselves on a TdV8 L320? If so please give a run down of what is involved. |
Mon May 07 2018 7:36am |
