Home > General > Roof rack advice please
Stevepd
So we've been thing of getting a roof rack and research shows two ways to go. We can have the roof rails fitted and put the bars on when we need or the clamp over the side method. Has anybody got experience of the roof rails version and if there are any obvious downsides likewise positives please. I'm leaning towards rails as it limits the potential for scratching the car as opposed to the whole rack on/off method. Aesthetics what does it look like fitted and anybody recommend companies to buy from.
Thanks as always
Steve. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #551616 Fri Mar 16 2018 3:56pm
Pufftmw
As you can see I have roof-rails. I personally don't mind the asthetics and I prefer these to the other type as I'm sure they see very sturdy. To me they look purposeful and don't detract from the looks. They're not something to take off regularly as it'd take a while, though they're easy enough to install. Cross-bars take a bit of time to learn how to put on but the trick is to make sure you move both sides along the slide at the same time.
Got mine from a forum member Smile
Couple of pics for you (it was p'ing down)
Oh & the rails are useful to hang onto when cleaning the car or loading things up Very Happy
Post #551623 Fri Mar 16 2018 5:39pm
Stevepd
Thanks for your reply, were these genuine parts or aftermarket. If not LR what's the fit like?. I've dropped Dan a pm as there is nothing in the FS section at the mo. 2006 2.7 TDV6 HSE in Cairns Blue.
Post #551624 Fri Mar 16 2018 5:50pm
Pufftmw
Genuine
I'd put a wanted post out as I'm sure they come up quite regularly & you never know what someone's got hiding in their garage
Post #551625 Fri Mar 16 2018 6:10pm
Cymruambyth
Wales
You can barely see those rails Cool Steve.
Post #551629 Fri Mar 16 2018 6:48pm
clarkey1
Roof Rails
Almost makes it look better Wink
Post #551669 Sat Mar 17 2018 2:56pm
Stevepd
Thank you all for your replies. Our car is in for a B service this Friday so will pursue it after that. Dan has kindly replied but I'll see what's on offer then Thumbs Up
Post #551675 Sat Mar 17 2018 4:09pm
