Home > General > Roof rack advice please |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
As you can see I have roof-rails. I personally don't mind the asthetics and I prefer these to the other type as I'm sure they see very sturdy. To me they look purposeful and don't detract from the looks. They're not something to take off regularly as it'd take a while, though they're easy enough to install. Cross-bars take a bit of time to learn how to put on but the trick is to make sure you move both sides along the slide at the same time.
Fri Mar 16 2018 4:39pm |
Stevepd Member Since: 22 May 2017 Location: Wiltshire Posts: 1251 |
Thanks for your reply, were these genuine parts or aftermarket. If not LR what's the fit like?. I've dropped Dan a pm as there is nothing in the FS section at the mo. 2006 2.7 TDV6 HSE in Cairns Blue. |
Fri Mar 16 2018 4:50pm |
Genuine
Fri Mar 16 2018 5:10pm |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 |
You can barely see those rails Steve. |
Fri Mar 16 2018 5:48pm |
clarkey1 Member Since: 14 Feb 2018 Location: Bucks Posts: 25 |
Sat Mar 17 2018 1:56pm |
Thank you all for your replies. Our car is in for a B service this Friday so will pursue it after that. Dan has kindly replied but I'll see what's on offer then
Sat Mar 17 2018 3:09pm |
