![]() | Home > Wheels & Tyres > Headache! |
GARYF123 Member Since: 03 Jan 2015 Location: leeds Posts: 143 ![]() ![]() ![]() |
My 2007 2.7 TDV6 came with 22" aftermarket rims. I managed to get hold of a set of 20" 7 spoke genuine Land Rover rims fitted with GG AT 275 x 45 x 20" tyres. I have resprayed and lacquered them and fitted new centres and tried to fit them yesterday but found that the wheel nuts wouldn't fit. This morning, I did a 40 mile trip to get some new ones and got down to fitting them - won't fit!!! Diameter clears the brembos but the back of the mounting face doesn't seat against the hub as the back of the spoke hits the brembos! The details on the back of the new rims are EH2 IS58 which I assume is 58 mm offset,
Hi Geoff, thanks for prompt reply,
It should be the same size as the hub |
Hi Geoff,
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
it will probably effect your camber setting RRS 3.0 SDV6 HSE Lux
Yes front and rears it will be worth having it checked after |
Just a couple more questions re spacers!
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Not that it matters as the wheel P.C.D are all the same, but just as a point of interest possibly, that particular rim was only ever fitted to the 2002-2009 Fullfat R/R.
